TNG Version 1.1.1.12 not costing calls
Postby abbyk » Wed Jun 04, 2014 2:48 pm
Hi Support,
I am having a problem with a TNG running on windows 8.1 where calls are not being charged correctly (or at all). I updated to version 1.1.1.12 to attempt to fix the issue but it still did not fix the problem.
On checking the costing via the rates tool, calls are not billed correctly. (TNG Rates Test),
Regards
MOOKETSI MOOKETSI
+267 3188800
abbyk
Re: TNG Version 1.1.1.12 not costing calls
Postby Belinda Frick » Mon Jun 09, 2014 6:34 pm
Dear Abby
You created the post under the wrong product, please refer to post under TNG:
TNG RATES IN BOTSWANA
