TNG Version 1.1.1.12 not costing calls (267 77)
Postby abbyk » Thu Jun 05, 2014 12:32 pm
Hi Belindah,
I am having a problem with a TNG running on windows 8.1 where calls (for 267 77...) are not being charged correctly (or NO Cost at all). See the attached file ...I updated to version 1.1.1.12 to attempt to fix the issue but it still did not fix the problem.
see the attached sample (SCREENSHOT) of 77 numbers that does not cost
and here are some of the numbers: 267 77663097 for testing
i have also attached the tng.ini file as you request.
i have also attached the raw.txt file from the client as request.
Regards
abbyk
Re: TNG Version 1.1.1.12 not costing calls (267 77)
Postby Belinda Frick » Mon Jun 09, 2014 6:35 pm
Dear Abby
You created the post under the wrong product, please refer to post under TNG:
TNG RATES IN BOTSWANA
