Amethyst IO Errors
Amethyst IO Errors
Postby Kpretorius » Fri Jun 22, 2012 9:22 am
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:30:33 amethyst kernel: end_request: I/O error, dev sdd, sector 67070586
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:31:15 amethyst kernel: end_request: I/O error, dev sdd, sector 67070587
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:31:57 amethyst kernel: end_request: I/O error, dev sdd, sector 67070588
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:32:40 amethyst kernel: end_request: I/O error, dev sdd, sector 67070589
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:33:22 amethyst kernel: end_request: I/O error, dev sdd, sector 67070590
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:34:04 amethyst kernel: end_request: I/O error, dev sdd, sector 67070591
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:34:46 amethyst kernel: end_request: I/O error, dev sdd, sector 67070592
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:35:29 amethyst kernel: end_request: I/O error, dev sdd, sector 67070593
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:36:11 amethyst kernel: end_request: I/O error, dev sdd, sector 67070594
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:36:53 amethyst kernel: end_request: I/O error, dev sdd, sector 67070595
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:37:35 amethyst kernel: end_request: I/O error, dev sdd, sector 67070596
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:38:18 amethyst kernel: end_request: I/O error, dev sdd, sector 67070597
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:39:00 amethyst kernel: end_request: I/O error, dev sdd, sector 67070598
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:39:42 amethyst kernel: end_request: I/O error, dev sdd, sector 67070599
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:40:24 amethyst kernel: end_request: I/O error, dev sdd, sector 67070600
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:41:06 amethyst kernel: end_request: I/O error, dev sdd, sector 67070601
[2012-06-22 08:42:00] Syslog log, : Jun 22 08:41:49 amethyst kernel: end_request: I/O error, dev sdd, sector 67070602
Last edited by Leon van Heerden on Mon Jun 25, 2012 5:03 pm, edited 1 time in total.
Reason: Changed the title
Kpretorius
Re: Errors
Postby Belinda Frick » Fri Jun 22, 2012 11:29 am
The Check Available Diskspace output does not show all the normal information, it looks like there could be a problem with the file system. Typically it should list under the 'Available Disk Space' section all the drives, which in your case should also include /dev/ssd.
There is an example of an 'Available Disk Space' in the forum post for your critical e-mail - see critical mail: ...kernel: ...I/O error, dev sdd
I will ask the Sales side to send you a quote for remote maintenance to log in and investigate.
Re: Errors
Postby Kpretorius » Mon Jun 25, 2012 7:53 am
Morning,
Please can you send a remote support quote so we can look at getting this reolved ASAP.
We getting hundreds of error notifications sent to our support inbox
Thanks
Kyle
Kpretorius
Amethyst IO Errors
Postby Leon van Heerden » Mon Jun 25, 2012 5:03 pm
I have checked the server and it looked like the Virtual Server could no longer see the USB devices. After the drive was restarted, i could mount the drive normally and check the disk space.
For safety I did a filesystem check on the USB Archive drive. One error was fixed.
The drive could be connected to a Windows PC and a normal
chkdsk /f
could be run on the drive to ensure that there is no errors.
After the check I ran a manual Archive and it looks like it is going through now.
I will check up again on the server to ensure that everything is working properly here after.
Return to Amethyst
