Ext being used is not one of the listed devises
Postby Karen » Mon Aug 13, 2012 1:58 pm
With the move one of the consultants extensions have changed. I have ticked the “Ruby ext” Check box on TOPAZ for 9873.
It reflects "Devise is not one of the listed ones". What steps did I miss? I need this ext to record as soon as possible. What do I need to change for this ext. to record?
Regards,
Karen
Karen
Re: Ext being used is not one of the listed devises
Postby Belinda Frick » Tue Aug 14, 2012 2:53 pm
When using trunk side recording all calls made via the configured trunks will be recorded. All extensions not listed on the AMETHYST Device List will be rejected. When you add an extension for recording, you only need to add the extension number to the list of Recorded Devices on the AMETHYST Webadmin Home page - please see forum link for steps to follow:
How do I add an extension for recording(trunk side solution)
Return to Amethyst
