IP Voice Recording - Auto popup for notes
Postby GreggB » Fri Jan 18, 2013 1:36 pm
Hi,
We need to make notes on the voice call while the call is active.
We would like an auto popup while on the call to take notes that will update the Subject on that voice call.
See attached
We user the IP/MAC address Voice Recording.
Please advise,
Thank you
Gregg
GreggB
Re: IP Voice Recording - Auto popup for notes
Postby Belinda Frick » Tue Jan 22, 2013 12:19 pm
For download of AMTClient install file and install steps, please refer to forum post:
How do I configure AmtClient 1.6
Postby Belinda Frick » Tue Jan 22, 2013 12:23 pm
To add to previous post. After you have installed AMTClient and if you meet the required AMETHYST version you can update to the latest version of AMTClient. This update can be loaded in AMETHYST webadmin and it will distribute it over the network to the agent PC (unless access restriction on the network blocks the update).
Release notes: AMTClient 1.6.4.2
Postby GreggB » Tue Jan 22, 2013 2:41 pm
Hi Belinda,
I have installed it and configured the ini's as per instructions.
I have even turned the windows firewall off.
But I still cant get it to pop up when an incoming call is answered.
We are using windows7
I pointed the ini to the Amethyst Linux box IP and not the IP Voice Recording windows box. Is this correct?
Please advise
GreggB
Postby GreggB » Tue Jan 22, 2013 3:25 pm
Hi Belinda,
See attached supervisor, Extension 9725 is 0825, we changed the number, will this have any affect?
GreggB
Postby GreggB » Tue Jan 22, 2013 3:38 pm
Hi Belinda,
I have added the physical device 0825 see attached, but it is still not popping up
GreggB
Postby GreggB » Wed Jan 23, 2013 7:37 am
Hi Belinda,
I see the INI file on our windows box that does the IP voice recording, still has the old 97xx numbers instead of the 08xx numbers.
How do I change this? I have changed it to 08xx and saved it, but it just goes back to 97xx
Please advise,
Thank you,
Gregg
GreggB
Postby Belinda Frick » Wed Jan 23, 2013 10:18 am
If the AMTClient on the agent PC can communicate with AMETHYST, it will auto update to show under 'Configure CTI Devices'. This part is working as per screen.
You will only have popups if recordings are taking place. Please check if your extensions are being recorded.
The instruction for popup on start of recording comes from the recording soft ware.
Postby GreggB » Wed Jan 23, 2013 10:37 am
Hi Belinda,
It is recording on x9725, but her extension has changed from 9725 to 0825
Please advise
GreggB
Postby GreggB » Wed Jan 23, 2013 10:49 am
I changed the extension to 9725 and the popup came up :)
the only problem is I need to change the extensions to the new 08xx range, see the ini screen shot I sent earlier
GreggB
Next
Return to Amethyst
