Amethyst critical errors report for Homechoice Pty(Ltd) (ame
Postby homechoiceTS » Fri Oct 18, 2013 9:59 am
Hi Belinda,
Can you Please assist with the below error on Amethyst.
To the Amethyst critical administrator
Amethyst has experienced some critical errors.
Critical errors should be investigated and must never be ignored.
[2013-10-18 07:50:08] Version [1.6.3.18]Archive error: Error unmounting NFS archive drive: Operation not permitted
homechoiceTS
Re: Amethyst critical errors report for Homechoice Pty(Ltd)
Postby Belinda Frick » Mon Oct 21, 2013 9:57 am
The message says that NFS cannot be unmounted. Usually it will do this if something is still busy on the drive.
Each night at 21h00 auto archive takes place. It will log any issue in the admin log. Please check the admin log for more details - refer to topic How do I know my archive/archiving was successful?
Return to Amethyst
