Amethyst/Linux hangs on startup: Gives error
Postby mosi » Wed Oct 30, 2013 9:14 am
Amethyst/Linux OS does not startup after a reboot.
It hangs on startup with error, attached is the screenshot of the error.
note that this is a VM. THe method used to restart was by going through the Webadmin>Configure Network> Apply Settings.
No changes were done on the Webadmin.
Please help.
Regards
Mosi
mosi
Re: Amethyst/Linux hangs on startup: Gives error
Postby Belinda Frick » Wed Oct 30, 2013 11:46 am
Do you have a USB drive connected to the AMETHYST server?
Postby mosi » Wed Oct 30, 2013 12:54 pm
there is no usb drive/device connected to the Amethyst Server.
The server is on a VM environment, the Blade chassis does not have any USB drives connected.
mosi
Postby Belinda Frick » Wed Oct 30, 2013 1:59 pm
On the console (where you took this screenshot), press Alt-F7 and check for errors on the screen.
Also check if you can log in to AMETHYST webadmin and Supervisor.
Postby mosi » Wed Oct 30, 2013 3:49 pm
i have done. refer to attached. i tried to access the webadmi and cannot access.
On the Webadmin, archiving is set to store on a network share. Can this cause the startup issue, as there is an additional IP address that maybe Amethyst is looking at and perhaps seeing it as an additional disk?
mosi
Postby Belinda Frick » Fri Nov 01, 2013 9:28 am
Has the issue been resolved?
From which company are you?
Return to Amethyst
