AMTSERVER has two IP addresses how to get AMTCLIENT working
Postby John Richard Procter » Fri Dec 20, 2013 1:35 pm
    The scenario is that you have a AMETHYST server or a Remote Amethyst.
  • The server has two NIC's one NIC is DATA and the other is VOICE.
  • The client is installed on a PC on the DATA network.
  • AMTSERVER has a option where you can specify the NIC what client communication must take place on.
  • Stop the AMTSERVER service add the following line to the configuration.
    Depending on which NIC the DATA IP address is.
[OPTIONS]
CLIENTNETWORKINTERFACE=eth1
Once done start the service again.
Return to Amethyst
