Amethyst Start up Error
Postby mosi » Wed Mar 12, 2014 9:56 am
Hi
I have done a reboot of Amethyst(Shutdown from web browser, then power off from the VM environment).
Refer to screenshot for error.
Thanks
Mosi
mosi
Re: Amethyst Start up Error
Postby Belinda Frick » Wed Mar 12, 2014 10:06 am
Thank you for the post.
We will discuss it internally and let you know if we require more information.
Postby mosi » Wed Mar 12, 2014 10:37 am
hi
Thank you. I can see that Amethyst is up. But its not putting in call details. Its recording with AMTCARDS on the User field.
Thanks
Mosi
mosi
Postby Belinda Frick » Wed Mar 12, 2014 10:47 am
To check if AMTMitel is running and receiving call details, refer to point 2 in the forum post:
How do I know AMTMitel is receiving call details?
Postby mosi » Wed Mar 12, 2014 11:03 am
Amethyst date and time is out. i looked at the AMTCARDS recordings and the log files, all of the information shows 08 January 2014. Could it be the reason Amethyst is recording with AMTCARDS
CHANNEL 88
0397275028
2014-01-08 03:53:09
0:13:57
mosi
Postby mosi » Wed Mar 12, 2014 12:13 pm
i have checked the How do I know AMTMitel is receiving call details?
All the settings on Mitel Controller are fine as mentioned on the document.
I have stopped and started the AMTMitel and SMDRLink services on Amethyst,
The license manager shows (Expired) and -53 Available Agent licenses
After starting, the log file for the AMTMitel shows
2014-01-08 04:48:32.737 [1.6.4.16] Settings: SMDR listen po: 27982
2014-01-08 04:48:32.737 [1.6.4.16] Settings: Keepalive interval: 30
2014-01-08 04:48:32.737 [1.6.4.16] Settings: Send Virtual: True
2014-01-08 04:48:32.737 [1.6.4.16] Settings: Debug logs: False
2014-01-08 04:48:32.737 [1.6.4.16] Settings: SendCTI: True
2014-01-08 04:48:32.737 [1.6.4.16] Settings: Controller: 10.100.0.2
2014-01-08 04:48:32.737 [1.6.4.16] Settings: extensions:
2014-01-08 04:48:32.737 [1.6.4.16] Settings: trunks:
2014-01-08 04:48:32.737 [1.6.4.16] Settings: skill groups: 7201=,7206=,7900=,7901=,
2014-01-08 04:48:32.737 [1.6.4.16] Debugging logs disabled
2014-01-08 04:48:32.758 [1.6.4.16] MiTAI libraries loaded - version MITEL Telephony Application Interface - Version 13.0.1.9_SP9 REMOTE. Initialising...
2014-01-08 04:48:32.759 [1.6.4.16] TSRCHandler Thread ID : 8605
2014-01-08 04:48:33.850 [1.6.4.16] TMiTAIController Thread ID for 10.100.0.2: 8605
2014-01-08 04:48:33.864 [1.6.4.16] Amethyst Mitel Interface started successfully
mosi
Postby Belinda Frick » Wed Mar 12, 2014 12:37 pm
Please let me know if your AMETHYST is up and running.
If not we will need to quote you for a remote call out and once accepted scheduled it.
Return to Amethyst
