Delete Physical Devices
Postby Eugene » Wed Aug 06, 2014 12:05 pm
If you want to 'free' a license to use for another device, you
need to use the 'Tick to deactivate' tick box of a device not in use
anymore. Please note: Once deactivated, you can only activate the
device again after 7 days. Therefore it will only be available for
recording after 7 days.
I went onto configured recorded devices but, I am unable to delete any?
What are the steps I am missing in order to do so, The devices I want to delete have been removed off the network.
Version 1.6.4.17
Eugene
Re: Delete Physical Devices
Postby Belinda Frick » Wed Aug 06, 2014 1:14 pm
If it shows that extensions was dynamically added by CRE, then the maintenance to add/remove extensions for recording is done on the Mitel side.
Please refer to post:
How do I add a handset for AMTMitelCRE 1.6.4+ for recording?
Return to Amethyst
