Amethyst critical errors report for Hertz
Postby aslam » Thu Mar 19, 2015 11:16 am
Hi
I am getting the following email from the system. Please advise.
To the Amethyst critical administrator
Amethyst has experienced some critical errors.
Critical errors should be investigated and must never be ignored.
[2015-03-18 21:07:41] Version [1.6.5.17]Archive error: Insufficient free space for database on archive drive: I/O error
aslam
Re: Amethyst critical errors report for Hertz
Postby Belinda Frick » Tue Mar 24, 2015 9:21 am
We need the following information to assist you:
  1. Size of the Database
  2. Screenshot of Check Available Disk Space
Please refer to forum post:
Critical mail: Insufficient free space for database
Postby aslam » Thu Mar 26, 2015 11:33 am
hi
please find attached screenshot
regards
aslam
aslam
Postby Belinda Frick » Thu Mar 26, 2015 6:49 pm
The archive drive usages shows 100% full.
You need to make archive space available. In your case the USB archive drive must be replace.
For steps see forum post:
How do I install a new external/usb archive drive?
Alternatively you can request a quote for a USB archive drive from Datatex. We can format and it will be ready to just be connected to AMETHYST. Next auto archive it should pick up and archive back log.
Return to Amethyst
