List of rejected extension per date
Postby Belinda Frick » Thu May 26, 2016 11:37 am
How do I pull the list of rejected recordings for a specific date?
cat /opt/amethyst/logs/2015012*/amtreject.log | cut -d "-" -f 5 | cut -d "|" -f 1 | sort -u
NOTE: This example is January 2015 from 20-29
Re: List of rejected extension per date
Postby Luanda_Junzi » Mon Jun 06, 2016 5:00 pm
cat /opt/amethyst/logs/20160606/amtreject.log | cut -d "-" -f 5 | cut -d "|" -f 1 | sort -u
Results
1008
1017
9024
9026
9032
9033
9034
9036
9046
9047
9048
9049
9050
9051
9052
9065
cat /opt/amethyst/logs/`date +%Y%m%d`/amtreject.log | cut -d "-" -f 5 | cut -d "|" -f 1,2 | sort -u -t"|" -k1,1
Gives you EXT and usernamee
1008|MFUNDO MKHWANAZI
1017|ZANELE MNGOMEZULU
9024|JUDY KARAM
9026|Tshepo Mbikwana
9032|NICOLA MATTHEWS
9033|Queen
9034|MESHA HARRILAL
9036|SHAMONA CHINNAPA
9046|EXT9046
9047|Travis Berry
9048|EXT9048
9049|EXT9049
9050|EXT9050
9051|Jezreel Snyders
9052|Calem
9065|EXT9065
Luanda_Junzi
Postby Belinda Frick » Tue Jul 19, 2016 4:38 pm
Create a file with a list of all the rejected recording references, showing the extension and user name:
cat /opt/amethyst/logs/`date +%Y%m%d`/amtreject.log | cut -d "]" -f 3 | cut -d "|" -f 1,2 | sort -u -t"|" -k1,1 > b1.txt
This is useful if you have more than one recorder and/or redundant recording and want to see from which recorder the rejected recordings are. Use the recording reference prefix to find the recorder:
B160719-0012C9.zlb - 8901|ONTVANGS
Return to Amethyst
