TES errors on page
TES errors on page
Postby Lee Hendricks » Tue Jun 05, 2018 3:55 pm
The TES server at Spoor and Fisher sometimes gets restarts.
In this case the TESwebdeamon is off and needs to be started up.
To start up the service, navigate to the location:
TYPE:
cd /opt/datatex/tes/webserver/
Run the following script to make sure that the webdeamon has stopped
TYPE:
./stopteswebdaemon
Wait for the "stopped" response
OUTCOME:
teswebdaemon: no process found
teswebdaemon.bin: no process found
This will confirm that the TESWEBDAEMON is stopped. Now start the service.
TYPE:
./startteswebdaemon
Confirm that the daemon is now running.
TYPE:
ps auwxf |grep tes
Check if the service is running
OUTCOME:
root       386  0.0  0.0  15404  1388 ?        Ssl  14:49   0:00 ./teswebdaemon -D
root       388  0.0  0.0   4444   652 ?        S    14:49   0:00  \_ sh -c ./teswebdaemon.bin >>/tmp/guardian/teswebdaemon.log 2>>/tmp/guardian/teswebdaemon.log
root       389  0.3  0.2 683020 11604 ?        Sl   14:49   0:14      \_ ./teswebdaemon.bin
The webpage should now be accessible
Lee Hendricks
Return to Amethyst
