Extensions configured on MBG but not on CRE config
Postby Lee Hendricks » Wed Jun 06, 2018 11:20 am
When myAccount logs the following error
These extensions have been pointed to the MBG but have not been configured on the CRE for recording:
2994
Please confirm if they should be added or ignored.i Ignored entries will no longer show up on this report.
IGNORED extensions can be added to cre_exclude_entries.txt
Full subject=Critical Error reported by check-cre at AVIOR for branch SANDTON
This is when a device is connected to the MBG but has not been configured
Confirm if they should be added or ignored.
If they should be added for recording. Follow the link below:
AMTMitelCRE 1.7+: adding extensions for recording
Lee Hendricks
Return to Amethyst
