Recordings for Amt1 and Amt2
Postby Lee Hendricks » Tue Jul 03, 2018 1:53 pm
At a site like CCD where recordings must be available in both the Amethyst servers, make sure that the correct script is running:
Confirm that the copyamt1andamt2.sh script is running
less /root/scripts/copyamt1andamt2.sh
Check that the script contains "/opt/amethyst/data/sweeper1/"
Check the location to confirmif there are recordings
ls /opt/amethyst/data/sweeper1/
If not all the recordings seem to be processing in then the issue is that the sweeper is not reading it from the correct location
Edit the amtsweeper
cd /opt/amethyst/bin/
Backup the current ini
cp amtsweeper.ini amtsweeper.ini-20180703
Edit the amtsweeper.ini
vi amtsweeper.ini
Change the directory:
ARCHIVEPATH=/opt/amethyst/data/sweeper1/
Startup the amtsweeper
./amtsweeper -D
The files that were left behind will now process in
Lee Hendricks
Re: Recordings for Amt1 and Amt2
Postby Belinda Frick » Wed Apr 06, 2022 2:23 pm
Return to Amethyst
