The following command will show all the change.log files that the webadmin is possibly picking up to process:
- Code: Select all
ls -l /opt/amethyst/bin/change.log* /opt/amethyst/bin/hdd/change.log* /opt/amethyst/bin/hdd/temp/change.log* /opt/amethyst/bin/nfs/change.log* /opt/amethyst/bin/nfs/temp/change.log* /opt/datatex/amtsweeper2/change.log* 2> /dev/null
Make sure that the archive is complete first and the change.log files are processed away successfully. There after the purge should work correctly.
If you do not have archiving enabled, the change.log file will have to be moved away daily before the purge runs, to ensure that the purge does leave those files on the server. Use the above script to make sure that old files are not still located somewhere on the server to process.
