AMETHYST2: How to I check the drive space of AMT2 server?
Postby Belinda Frick » Tue Dec 08, 2020 2:08 pm
QUESTION:
I need to see the space allocation of the drive space on the AMETHYST2 server.
How can I check this?
OVERVIEW:
There is an option to pull a manual report, the System Status report, which indcludes disk information.
SUGGESTION:
  1. Log into Webadmin:
  2. From the HOME page select the 'STATUS' icon under Reports section:
  3. You have the options to Show or Send the report.
    To send it, you must enter an e-mail address.
    NOTE: Allow time to pull report information, it will display once done.
  4. Disk space information is displayed under the section 'Disk Information', for example:
    Drives:
    Archive:
    Autopurge:
Reason for unable to display 'Disk Information':
  • Drives: Error getting disk information
    This could be caused by the archive share/drive being mounted.
    Solution: re-run the Status report
Re: AMETHYST2: How to I check the drive space of AMT2 server
Postby Leon van Heerden » Mon Dec 14, 2020 12:22 pm
If the Archive drive takes to long to mount, the page might display before the disk space is shown and then there would be an "Error retrieving disk information".
Return to Amethyst
