How to check if a NFS share is accessible
Non-Datatex Product Support.
Postby Leon van Heerden » Tue Apr 03, 2012 5:33 pm
Requirements on Ubuntu Linux:
Packages that must be installed: nfs-common
If you are testing this from a Linux server, you can run the following command to see the shares on the server.
showmount -e 192.168.1.2
You should see and entry for your share listing who has access to the share:
Export List for 192.168.1.2:
/MyShare (everyone)
Please note that the share is case sensitive.
Now you need to mount the folder:
mount -t nfs 192.168.1.2:MyShare /mnt/nfs_mount_location
You should now be able to access the folder if your permissions are configure properly.
If you don't have permission to access the NFS share, you will just get a "Permission Denied" error when you try to enter the mounted folder. Re-check your file system permissions on the NFS server side.
Return to General Support
