Non-Datatex Product Support.
by John Richard Procter » Mon Jan 14, 2013 4:21 pm
- Create a folder in a Windows which you want to have shared on your network.
- E.g. A folder on the desktop TSP
- Select share this folder and the name you want others to see.
- Select the permissions of the folder
- By default the everyone user has access to view the files but not write.
- If you want the Share to be written to by anyone give the user full control.
- To have a secure share select a user on the domain and remove the everyone user.
- Also add the permissions under the folder security tab and give user the required access.
- To test the share location
- Windows key + R to run followed by the IP address and location of the shared folder
- The share folder will be opened.
- If connecting from another user without access to the share.
The following message will appear
Return to General Support
