SQL error on Database when using AMTLISTEN
Non-Datatex Product Support.
Postby Proodt » Mon Nov 18, 2013 9:48 am
When I Use AMtlisten to open archived recordings it comes back with an error
"Could not connect to database : SQL server Error: unsupported on disk structure"
What do I need to do to use AMtlisten
Proodt
Re: SQL error on Database when using AMTLISTEN
Postby Belinda Frick » Tue Nov 11, 2014 12:04 pm
This can happen if the archived database was done with 32-bit Firebird and AMTListen is installed with 64-bit Firebird.
Certain domains have permission issues that give constant errors when trying to use AMTListen.
We advise against installing AMTListen on a pc that is on the domain
Please try the following work-a-round:
  1. Download and unrar the content of the file in the folder where amtlisten.exe is present:
    Firebird 32&64 Bit.rar
    Password is 'datatex'.
    NOTE: To download the file, you need to be logged into the forum.
    It contains the following files:
    NOTE: The files must be save in the same directory as the amtlisten.exe file.
  2. When using the older archived database, run the olddb.bat file.
    When using the new archived database, run the newdb.bat file.
    NOTE: The bat files was written for a 64-bit PC. If you use a 32-bit PC, you will need to edit the file path to not contain X86.
    The bat file will copy the correct fbclient.dll that will allow connection to the database and open AMTListen.
Return to General Support
