TNG - invalid installation
Non-Datatex Product Support.
Postby kalr » Thu Jan 14, 2016 1:06 pm
Good day
Please see the attached log file as requested.
Kind regards
Kal
kalr
Re: TNG - invalid installation
Postby Luanda_Junzi » Thu Jan 14, 2016 2:54 pm
Thanks Kalr
Can you attach another log, you can take the whole day log zip and attached on this post, the errors am looking for are not on this log.
kind regards
Lwanda
Luanda_Junzi
Postby kalr » Fri Jan 15, 2016 8:26 am
Hi Lwanda
I notice there is a gap of a few days between December 2015 and Jan 2016. Also the server did shut down pre-maturely around the 18 Dec2015. I have confirmed that the csv file, that TNG imports from, does exist and is up to date. However there is no raw.txt file in the folder since then. I have attached the two log files during the time mentioned above.
thank you for your assistance.
Kind regards
Kal
kalr
Postby Luanda_Junzi » Fri Jan 15, 2016 8:30 am
Thank you kal for the logs.
I will investigate and update the post in the course of the day.
Regards
Luannda
Luanda_Junzi
Postby Luanda_Junzi » Fri Jan 15, 2016 9:30 am
Good day Kal
I see this error on logs, can you reload the csv, file.
2015-12-18 01:52:04:221 [1.0.7.7] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/TNG.csv" does not exists [Repeated 50 times]
You are running TNG version 1.0.7.7 and currently we running is 1.1.1.13 .I strongly advise the upgrade.
2015-12-18 05:55:03:494 [1.0.7.7] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: Local/1869@from-queue-2876;2[10]UniqueID: 1450410892.403862[10]DialStatus: CANCEL[10]
Dial Error are resolved on the latest version.
Regards
Luanda
Luanda_Junzi
Postby kalr » Fri Jan 15, 2016 11:33 am
Thanks Luanda
I am going to try this and get back to you.
kind regards
Kal
kalr
Return to General Support
