Release notes: TAPIAssociate 1.6.3.2
Postby Hilton Williams » Mon Aug 22, 2011 12:16 pm
  • Added a new setting where the timeout before TAPI re-connects are done is configurable in the INI file.
The default timeout for starting up TAPI was one minute. If after one minute, all the TAPI devices were not open, the TAPI connection would be restarted. Some TSPs that show all the devices on the PABX (e.g. Samsung) were taking a long time to open, with the result that if it took longer than one minute, TAPIAssociate would close the connection and try again, effectively never starting up correctly. The timeout is now configurable.
The value is in the INI file, under SETTINGS, named CONNECTTIMEOUT, values are in seconds, default is 60.
Hilton Williams
Return to Releases
