Release notes: VoIPRecorder 1.6.3.41
Postby Hilton Williams » Mon Aug 22, 2011 12:42 pm
  • Fixed bug where the size of the internal RTP buffer was one too many, causing conversions to fail.
  • Fixed minor bug where the file size of the combined PCM file was based on the "_r" file, and if this was shorter than the "_l" file, some audio at the end of the file would be lost. The resulting file is now padded with silence for the shorter stream.
  • File conversion errors now have the filename included in the error, and are also sent to the event monitoring system.
  • Fixed bug where deleting a station would cause access violations in kernel32.dll.
  • Packet check threads are now terminated quicker, resulting in a quicker shutdown.
  • Added code which handles the multiple synchronisation sources.
  • Added jitter buffer code from the CRE, but limited to 20 entries, and has an overflow flag when adding entries - if it overflows, a critical warning is sent to the AEM, a marker with a "*" is added, and the error is written to the log. The AEM and log entry can only occur once per file. The file is processed.
  • Now sends quota exceeded messages on startup to the AEM.
  • Fixed bug where last station dump time was not being set, causing it to dump stations every second.
  • Minor change using the USC codec - it now doesn't raise an access violation when it fails to load the dtxIPP.dll.
  • Added check for blank keys when writing the MAC / Extension mappings (fix for ntdll.dll errors).
  • The raw RTP for an unknown payload type is now dumped to the log (only once for the file), to make it easier to find the problem.
Hilton Williams
Return to Releases
