Release notes: VoIPRecorder 1.6.3.46
Postby Hilton Williams » Mon Aug 22, 2011 1:06 pm
  • Work-around for Cisco CM 8.5 problem where ACD group numbers appear in the called field, and we use this for our extension number. Now a list of groups can be configured in a GROUPS section in the INI file. Entries must have = signs after the group number. When a group comes through, the extension is no longer set. Number and direction are still set.
  • Work-around for Cisco CM 8.5 problem where the called and caller fields are both the telephone number. The extension is no longer set based on this information. Number and direction are still set.
  • Fixed minor bug where last packet of each RTP stream was not being converted.
Currently, usernames for the group problem appear to be valid in the call information, but for both cases, we no longer use the provided username, relying on the Amethyst Sweeper to fix this using the previous username given.
Hilton Williams
Return to Releases
