by Hilton Williams » Mon Aug 22, 2011 1:14 pm
- Fixed bug where GETLASTINFO request was not being used.
- Fixed bug where CheckRestart (on transfers) was not resetting the starting time, resulting in incorrect duration.
- Fixed a bug with Datatex switchboard where telephone number was not coming through from the ACD group device in all cases.
- CRE can now terminate calls on AMTMitel again. The CRE is not allowed to terminate a call if it was terminated less than 2 seconds ago (fix for late request).
- This version works correctly with transferred calls on consoles - the fix was to terminate calls on consultation hold, to allow trunks to terminate calls on established events, and also to have CheckRestart check that the call IDs involved have actually changed, to avoid terminating again.
- Decreased duration of time that call details are kept - 3 seconds was too long.
- Added code to set account code field, but not used yet.
- Calls on DNs where monitoring did not work, can now be started by other DNs (fix for console phones and announced transfers). This feature is called "remote start". When finishing a call, a check is now done for remotely started calls and those are terminated too. Effectively, this means a DN that starts a remote call will finish that remote call.
- Added support for re-opening DNs on a regular basis, but no code for this yet.
- MiTAI library version is now always shown in logs at startup.
Hilton Williams
Return to Releases
