Release notes: AMTCards 1.6.3.15
Postby Hilton Williams » Mon Aug 22, 2011 1:36 pm
  • Added zero voltage timeout for analogue lines. This allows the user to configure the duration of zero voltage before the cardserver decides a channel is faulty. Default is 30 seconds, maximum is 5 minutes. This is configurable per channel in a new section named VOLTAGETIMEOUT - the entries are the slot_channel=value format.
  • Added support for altering the extension field using CLI rules - CLI rules now supports a REPLACEFIELD action, which replaces the entire value entered with the new one.
The zero voltage timeout is for cell routers which take a long time to reset, more than a minute in some cases.
The extension field change allows clients who transfer calls out to cell phones on a trunk-side solution to change the trunk number that appears in the extension field to something else.
Hilton Williams
Return to Releases
