Release notes: AMTMitelCRE 1.6.4.6
Postby Hilton Williams » Mon Aug 22, 2011 1:39 pm
  • Avaya Dialer integration via external call control (an external application controlling the CRE recordings).
  • Fixed major bug where the CRE would almost always be killed off if it tried to process a 2 GB PCM file.
  • Fixed bug where CRE would not create a recording if the RX SIF file exists and is zero bytes.
  • Fixed minor bug where PacketProcessor was not being freed on Shutdown.
  • Preferred IP is now reloaded. The preferred IP change is due to an issue found at a client when changing the network settings on a machine with multiple interfaces.
Hilton Williams
Return to Releases
