Release notes: Supervisor version 1.6.4.4
Postby Belinda Frick » Thu Nov 10, 2011 1:18 pm
Supervisor version 1.6.4.4 displays the unencrypted recording checksums on the recording screen. It requires that the Amethyst server be at least version 1.6.4.0. NOTE: Upgrading to server 1.6.4 makes database changes. First run the AMETHYST server upgrade and then Supervisor 1.6.4.
Changes since version 1.6.3.23 (included in the Amethyst 1.6.3.18 update):
Amethyst Supervisor version 1.6.3.24
The initial screen after login is now the search screen, and not the agents screen.
Amethyst supervisor version 1.6.3.25
Fixed a bug where screens wider than 1600 pixels and smaller than 2000 pixels would have the search screen toolbar displayed off the screen.
Amethyst Supervisor version 1.6.4.0
Extra info displayed on recording information screen (requires Amethyst server version 1.6.4.0 or later).
"Search for recording id" is now before "search any" on search screen, so one can press enter after typing in a recording id.
No longer shows ".GSC" portion of recording ID.
Amethyst Supervisor version 1.6.4.2
Tagged recordings were not showing correctly on the pie charts.
Amethyst Supervisor 1.6.4.3
UUID creation code replaced since the old code was leaking file descriptors on Ubuntu. After approximately 1000 logins, this problem would cause the Supervisor to stop working correctly.
Amethyst Supervisor version 1.6.4.4
Added MD5 and SHA256 checksums to recording information screen, so they can be used to validate the e-mailed recordings.
Return to Releases
