Sweeper changes since AMETHYST 1.6.3.18 to 1.6.4.7
Postby Belinda Frick » Tue Mar 27, 2012 3:37 pm
Sweeper changes
  • Version 1.6.3.15
    Sweeper now gives warnings (via e-mail and AEM) when too many consectutive "EXT" recordings are processed. The default value of "too many" is 10. This is configurable in the INI file, under OPTIONS->MAXCONSECUTIVEEXT=10.
  • Version 1.6.3.16
    Fix for screenshots when using new CRE recording id format.
  • Version 1.6.4.0
    Added support for extrainfo field. This contains information about codecs used, problems encountered, etc. (requires at Amethyst server version 1.6.4.0).
  • Version 1.6.4.1
    Added code to skip ZLB files if another process is busy with them - this is to fix problems with Pure-FTPd 1.0.24 and later which don't have atomic uploads (the uploaded file is uploading under a different name). This causes the Sweeper to process the file before it finishes on slow FTP uploads.
  • Version 1.6.4.2
    Added support for "always use virtual extension names". The Sweeper will do lookups against the virtual extension names first, and if no name is found, it will fall back to the default behaviour.
  • Version 1.6.4.3
    When Sweeper is configured to control AQM marking of recordings, it now ignores the fact that screenshots are present. Previous versions would mark calls with screenshots as AQM as well.
  • Version 1.6.4.5
    Will no longer stop processing if file has been locked for 10 attempts (the change introduced in 1.6.4.1).
  • Version 1.6.4.6
    Changed the way that redundant Amethyst works - there is now a redundant license, and if that is present, all recordings are accepted.
  • Version 1.6.4.7
    Bug fix in ZLB units to fix hang when extra data has been added to the compressed files.
Return to Releases
