VoIPRecorder version 1.6.4.15
Postby Belinda Frick » Tue Mar 19, 2013 11:11 am
NOTE:
Ensure your AMETHYST is on version 1.6.4.15 before you run these updates - refer to forum post: Which versions of the software is part of the AMEHYST 1.6.4.
Required versions:
  • VoIPRecorder version 1.6.4.15
    Unrar to find the executable:
    VoIPRecorder-version_1.6.4.15.rar
    To update: Make a backup of the VoIPRecorder exe and ini. Stop the VoIPRecorder service, replace the exe, start the service.
  • VoIPSweeper version 1.6.4.17
    Download and unrar:
    amt-voipsweeper-install_update-1_6_4_17.rar
  • Server version 1.6.4.18
    AMETHYST server version 1.6.4.18
To upgrade via AMTWebadmin refer to forum post - How do I upgrade with AMETHYST 1.5 /1.6?
Release notes: VoIPRecorder version 1.6.4.15 (29 February 2013)
    Better support for Avaya.
    Changed the way duplicated numbers are handled.
    Tap starts recording with a new reference after 4 hours have passed.
    Added support for AUX stream recording.
    Also see VoIPRecorder release notes: 1.6.4.9 to 1.6.4.15
Return to Releases
