Release notes: AMTServer 1.6.4.22
Postby Belinda Frick » Tue May 28, 2013 11:19 am
Release notes:
  • Version 1.6.4.20
    Added SIPRecorder to list of monitored recording software.
    Fixed bug where the Recording software monitoring was only reading 1 line every second from the AEM, possibly causing monitor error messages to be delayed on busy sites.
    Fixed bug where it would write to the CTI devices too often, sometimes making it difficult to change settings in the Web Admin.
  • Version 1.6.4.22
    Force a disconnect after communication with AMTClient on port 27009 - this avoids problems on bad networks where Amethyst may lose communication with a client and not know it, using up file descriptors until it runs out.
    Moved the software monitor thread start to before the status e-mail is sent, since delays getting status information prevents errors from being sent out.
    This version closes all file descriptors before starting, since it was inheriting the list of Web Admin file descriptors as well, causing some to be unusable.
Fixed:
a bug in the Server application - clients connecting and disconnecting can cause it to run out of file handles.
NOTE:
    To upgrade to AMETHYST 1.6.4.22 your AMETHYST must be on version 1.6.4.
    There was database changes made between version 1.6.3 and 1.6.4
    Download and unrar:
    server-guardian-1_6_4_22.rar
    To upgrade via AMTWebadmin refer to forum post - How do I upgrade with AMETHYST 1.5 /1.6?
Return to Releases
