- Decreased thread stack size to 1 MB - previously I think it was 8 MB, and only 20 stations could be added. Also added PE flag for "Large Address Aware" to allow more than 2 GB RAM to be used, same as previous Delphi versions. I tested this at
- 500 stations (2.8 GB RAM used), which is the maximum for the current USB handling method.
Download and unrar, password is 'datatex':
Steps:
When updating no recording will take place, please check upgrade according to recording hours.
- Make a backup of the VoIPRecorder ini and exe.
- Run the 'exe'.
- Check the VoIPRecorder log that the work stations loaded and are recording.
If you are using an older version of the VoIPRecorder software, you will have issues with the upgrade.
For version 1.6.4.12 and older, you need to uninstall the VoIPRecorder service in Windows Command Prompt and then run the upgrade to install the newer version of the VoIPRecorder service.
