This is an update for the VoIPSweeper to fix the problem where the one side of the conversation sounds strange on long recordings.
Other changes from the last version (1.6.4.33) are:
- Fixed bug where it gives access violations when processing calls when failover is not configured.
- Does a imperfect strip of duplicate packets before sorting the packets - this reduces the amount of memory used so that larger recordings can be processed. The perfect duplicate strip is then done with the sorted packets, which is the correct way. However, the vast majority of recordings will be in perfect sorted order already.
- Added RTP statistics similar to the CRE to the recording information.
- Added processing of WAVE audio files to support SmartWORKSPlus (Microsoft Lync) recording - currently only G.711 and 16-bit signed linear PCM files are supported.
Update process:
- Always make a backup of the VoIPSweeper.exe and the ini.
- Run the update exe.
- Check that the log does not have any errors.
