Release notes: Remote AMETHYST server 1.6.5.22
Postby Belinda Frick » Tue Oct 07, 2014 11:39 am
  • Version 1.6.5.14
    Added database changes for 1.7 Supervisor.
  • Version 1.6.5.15
    Fixed bug where the server was logging blank error messages for dynamic device updates - shows "HandleConnection" in log.
  • Version 1.6.5.16
    Now uses "client network interface" to determine the IP that is used to connect to the AEM.
  • Version 1.6.5.17
    Added debug logs for messages sent to clients.
  • Version 1.6.5.18 (not released)
    Added licensed option "EXT All Rule", which can change all non-matching extensions on the forwarding rules to "EXT".
    Note: this functionality did not work correctly in this version - please use 1.6.5.19
  • Version 1.6.5.19 (released)
    Fixed bug in the EXT All Rule code - it now works properly.
    This version still has a bug where it crashes.
  • Version 1.6.5.20 (not released)
    Compiled to use old Indy TCP code as a work-around for TCP-related crashes.
  • Version 1.6.5.21
    Fixed bug in TCP handling where it could cause a crash - new Synapse TCP code is in use again.
  • Version 1.6.5.22
    Re-compiled for Windows.
    Reading AEM messages is now faster.
    Added support for PCI module.
Steps:
amt-remoteserver-install_update-1_6_5_22.rar
  • Unrar attached, password is datatex.
  • Double-click to run exe.
    NOTE: if you use AMTClients at the remote branch, it will not work during update time of amtserver.
Return to Releases
