- Version 1.6.5.16
Fixed serious bug in the forms introduced in 1.6.5.15 – the old behaviour is back where the forms are hidden. - Version 1.6.5.15 (do not use, use 1.6.5.16 instead)
Errors opening the dynamic device update port (TCP port 27003) are now sent as critical errors.
The "stop" menu entries now prompt for confirmation.
Changed cardserver list and edit menus to a configuration screen for all server-based recording solutions.
Added VoIPSweeper configuration (requires VoIPSweeper version 1.6.4.41 or later).
Changed the way the forms are submitted - it no longer hides the buttons and input fields, but disables them.
Added Amethyst server configuration to VoIPRecorder and SIPRecorder.
Removed unused configuration options from VoIPRecorder configuration screen. - Version 1.6.5.14
Fixed bug where Ubuntu servers would not be restarted when the networking configuration was changed (broken in 1.6.4.16). - Version 1.6.5.13
Fixed bug where the Web Admin would clear the SRC configuration if no devices are configured for a SRC on the CRE configuration screen.
Added option to configure the Amethyst Server and added Cisco settings to the SIP Recorder configuration screen.
Added error handlers for database errors when doing the status report.
