This update now allows the cached lookups for usernames to be disabled . This is used at sites where multiple PABXs with overlapping extension number ranges are used. The same extension can appear of 2 different PABXs and there should not be a cached lookup for those extensions.
To disable this lookup, add the followin setting to the amtsweeper.ini
- Code: Select all
[OPTIONS]
USERNAMELOOKUPS=0
Version 1.6.5.12
When a surveyed recording is processed by the Sweeper, the reference field is populated with "SURVEYED".
Version 1.6.5.10
Added support for Survey system
Version 1.6.5.9
Added a check for ZLS files being FTP'd slowly - it now checks if any other process is using the file and skips the file it is in use.
