How to report an problem
This forum covers App specific issues
Postby Leon van Heerden » Thu Nov 05, 2015 10:24 am
We require the following information to try and assist. Please create a new post explaining the issue that are experiencing. Then answer these questions. A simple way is to copy these questions and paste them in your post and answer next to each question;
  1. Make and Model of mobile device:
  2. Version of Android
  3. Is the device running Stock version of Android or Custom ROM:
  4. Is the device rooted or not?
  5. Which version of iReCall do you have installed?
  6. Is iReCall installed on a SD card or on the internal storage?
  7. Which Audio Setting are you using to make your recordings?
  8. Do you have a White list or Black list configured?
  9. Are you using the WiFi only setting?
  10. How are you using your device to make calls?
    (Directly through normal handset/ Blue tooth / Wired Head set/ Speaker phone/ other)
Return to iReCall Mobile App
