Amethyst support hardware, requirements and configurations
by Belinda Frick » Tue Feb 15, 2011 10:28 am
We will now include the following settings as standard for installing a Windows 7 Cardserver:
- Disable power options not to let Windows go to sleep after 30min
- Set the power saving options in windows not to turn the hard drives off after being idle for 20 min
- Microsoft Security Essentials:
- Settings -> Exclude Files and Locations:
- browse to the AMETHYST folder and select it - click on ADD
- browse to the SMARTWORKS folder and select it - click on ADD
- Settings -> Exclude: Processes:
This is to exclude the recording software exe's (amtcards.exe/amtmitelcre.exe/VOIPRecorder.exe).
- Windows 7 Cardservers must have at least 4 GIG memory(Windows 7 requires 2 GIG).
- enable remote desktop Under "Enabled Features".
- Uninstall Media Center, but leave media player.
- Install Telnet client
Return to Hardware
