error: "HCI/CTI/telephony option TAPI must be in affect"
Postby Belinda Frick » Wed Feb 09, 2011 3:08 pm
On the Mitel PBX Configuration, in the "Class of Service" Option assignment the following settings is required:
"HCI/CTI/TAPI Call Control Allowed"  = YES
"HCI/CTI/TAPI Monitor Allowed" = YES
If you click on save it gives the message:
Then the TAPI Licensing must be enabled under licensing for the Mitel.
This will require a Reboot. Please note that the reboot can take up to 15 minutes or more.
Enable the tick box/radio control for "TAPI / CTI"
Please schedule reboot according to company requirements.
