Cable lengths for all recording cards
Postby Belinda Frick » Fri Feb 25, 2011 10:56 am
Card and connection: SmartWORKS DP (E1 PRI)
Supplied length:4 metres
Maximum recommended: 16 metres
Comments: For recording Primary Rate ISDNE1 is the European standard for ISDN, used in South Africa.
Card and connection: SmartWORKS DP (T1 PRI)
Maximum recommended: 30 metres
Comments: For recording Primary Rate ISDNT1 is the American standard for ISDN, used only in the USA.
Card and connection: SmartWORKS NGX (BRI)
Comments: For recording Basic Rate ISDN and digital extensions
Card and connection: SmartWORKS PT
Supplied length:N/A
Maximum recommended: N/A
Comments: For recording analogue trunks and extensions. This board is discontinued
Card and connection: SmartWORKS LD
Maximum recommended: 60 metres
