The data will be stored on the PC untill it can update to the server.
If the PC is switched off before the update time, it will wait until the
next update time, therefore if the PC is always off when it is set to update
the server the recordings will stay on the PC.
To get these recordings onto the server:
1. set the update time to when the PC is still running.
2. You can also right click on the user in the Amethyst server and select the
"FTP now" option. All recordings will then be sent immediately.
