I can see the agent on the AMETHYST server,not Supervisor
Postby John Richard Procter » Thu May 05, 2011 10:06 am
The agent is not associated with the supervisor.
AMETHYST Server
  • Open AMETHYST Server.
  • Click on Configure Agents.
  • Select the supervisor on the left.
  • Now select the agent that you want the supervisor to see
    from the right (tick it)
  • Click Apply.
  • Click OK.
NOTE: The agent will not appear on the right-hand side
unless a recording exists for it.
TOPAZ:
  • Open TOPAZ
  • [DATA -> USERS ]
  • Next to the "Find" tab enter the user, click on "Find".
  • Check that the usernames do not contain a single quote
    characters.
  • Make the change, click on the tick to save.
  • After the change, the agent will be picked up by AMETHYST.
