Showing recording , but no recording found afterwards
Postby Belinda Frick » Tue Nov 16, 2010 8:13 am
Check the MINLEN value in your SLVR. If the value of this variable is set to
high, the recording will not be saved to the database.
E.g. if MINLEN = 60
That is 1 minute, any recording shorter than a minute will not be saved to the
database.
A recommended value would be between 7 and 15 seconds.
