The AMTTAPILINK program crashes on opening it.
Postby John Richard Procter » Thu May 05, 2011 11:11 am
It was reported at a site, where a power failure occured,
that when the AMTTAPILINK program starts up, it crashed.
This is because the folder it created for the log file was
read only and therefore could not create the log file. The
program crashes because the log file is not present.
At this site the acces rights seemed ok. The problem was
resolved by re-creating the access for to the folder for
the Windows user.
Steps followed:
1. Remove simple file sharing on the Datatex folder.
2. Remove and add the Windows user under folder settings.
