AMT USBCLT log:error creating journal: the operation Failed
Postby John Richard Procter » Thu May 05, 2011 4:04 pm
The USBclient is trying to write a Journal entry to Outlook.
If you need the Outlook integration, you need to install Outlook on the PC
with USBClient.
If not, they can disable the Outlook integration. You can disable it by going
to the Amethyst Web Admin main screen, clicking on "Outlook integration" at the
bottom, and removing the tick in "Enable Outlook integration". Afterwards you
have to go to "Redirect to IP address" or "Redirect to hostname" to get the
USB clients to update.
Under investigation!
AMT=Amethyst
CLT=Client
