by John Richard Procter » Mon May 16, 2011 1:28 pm
To check if recordings is being loaded:
AMETHYST Webadmin under Recording section, click on 'View Call History'
calls for the last hour.
You will need to check the logs to see why it happened:
AMETHYST Webadmin -> Configure Cardserver/CRE -> View log.
Under investigation!
