No call termination for all recordings made with USBClient
Postby John Richard Procter » Fri May 27, 2011 12:32 pm
  1. They are using the ODN (Direct number, private number) setup
    (must use it with the MaestroTel. With this setup it will
    give off the physical extension number or the ODN number
    (each extension has their own unique ODN number).
    Use the physical extension number for USBClient. To link the
    physical extension number to the ODN number use the virtual
    extension setup, provided that it is also the same Windows
    user loggin used to log into the PC that USBClient is
    installed on for the ODN number.
  2. By default SMDR data on the Ericsson MD110 is set to low priority.This means that if the PABX is very busy there will be delays in
    sending of the call data string. This will cause calls not to be
    terminated. However it can tie up with recordings when sent of and it
    can therefore also cause the 'wrong' call details to be attached to
    the recording.
  3. Note that USBClient requires real-time data, therefore if the PABX
    has 2 ports for SMDR output ensure that the one you are using is set
    to real-time.
