by John Richard Procter » Fri May 27, 2011 12:42 pm
You will receive this error in the server log when:
- Amethyst is trying to send to a blank hostname. It should not be doing this.
The fact that there is a blank hostname might indicate a problem though. If you
have AMTClients or USBClients, ensure that software is running on all recorded
extensions,
- It is also possible that the AMTClients or USBClient software is not updating
the AMETHYST server correctly,
- The AMTClient or USBClient software is closed and AMETHYST cannot send information to it.
