critical errors: MTArmFramerAlarm for YELLOW_Alarm
Postby John Richard Procter » Fri May 27, 2011 1:19 pm
These "errors" are always there when a Cardserver is restarted.
It is where the cardsevice sets the triggers for those alarms.
You will notice that the line doesn't start with ERROR, see
examples below:
[2008-11-19 12:48:12] Version [1.0.7.19]MTArmFramerAlarm for
YELLOW_Alarm(2) (E0002012 on channel -1)
LOS_Alarm(2) (E0002012 on channel -1)
LOS_Alarm(3) (E0002012 on channel -1)
