What is required for screenshot when running a trunkside rec
Postby John Richard Procter » Mon May 30, 2011 1:02 pm
  1. TAPI or CTSA integration is needed (currently we only
    support TAPI).
  2. Realtime information which will provide the trunk and
    extension
    number when the call starts (for example on
    a LG we use the ACD data). We need the trunk number
    to map the channel on the recording card and the
    extension number to map to the PC AMTCards is running
    on.
  3. If virutal extensions is used, we will need mapping
    between the virtual exension and the physical
    extension
    aswell as which user name is working on
    the PC(on the Mitel the ACD port provides the
    physical and virtual extension number).
Examples of PABX's curently supported:
  1. Mitel (ACD info and TAPI)
  2. Erircsson BP and MD (Tapi Required)
  3. LG (ACD Information)
  4. Panasonic (TAPI info)
